nenaang
Feb 29, 2020Aspirant
Old Encryption Error
Hello all, I had a family member connect today and they told me that their ASUS gave them a warning about old encryption. I’ve searched everywhere and do not see this mentioned. Any idea what’s cau...
- Mar 01, 2020
You should be able to update to v2.5.1.8 directly on the RBS first then RBR lastly.
https://www.netgear.com/support/product/RBK50.aspx#download
Download the .zip files for each RBS and RBR. Unpack the .zip file to reveal the .img files. Use IE11, Firefox or Opera web browser on a wire connected PC to send the .img files manually.
Once you get the RBS and RBR updated, factory reset both units and setup from scratch.
nenaang wrote:
Firmware version: v2.3.5.30
Asus T100 (tablet)
WPA2-PSK
Mar 06, 2020Guru - Experienced User
Glad you got it working. Be sure to save off a backup configuration to file for safe keeping later on. Saves time if you need to reset later on down the road.
Please mark your thread and solved.
Enjoy. :smileywink:
nenaang
Mar 06, 2020Aspirant
Thanks for the tip! How do I save a backup configuration?!
Noted with thanks: I’m not sure if marking it solved will close the thread so I’ll wait for a response on how to save before marking resolved..! :)
