LanceD
Jan 07, 2020Guide
Orbi AC3000 system constantly dropping Wifi
I've read through this board and have seen a few similar queries, but haven't found any answers to my issues in them so posting this. After much tweaking and fiddling with router and satellite lo...
SW_
Jan 07, 2020Prodigy
LanceD wrote:I've read through this board and have seen a few similar queries, but haven't found any answers to my issues in them so posting this.
Here's my current setup:
1) Xfinity Technicolor TC8717C modem/router with 200MB/S plan. I am using the router capabilities but the WiFi radios are disabled.
2) Orbi router set to AP mode, wired connection to router via LAN port.
Anything else I could try?
If the Orbi LAN is currently connected router LAN port, disconnect/reconnect Orbi yellow (WAN) port to TC8717C LAN port.
LanceD
Jan 07, 2020Guide
Thank you for the note. That is indeed how I have the modem and router connected (Xfinity LAN to Orbi WAN). Sorry I wasn't clear about that.
- SW_Jan 07, 2020Prodigy
In that case, disable Daisy-Chain and verify that backhaul signal is within dBM range, between -30dBm and -70dBm, by pointing your browser at http://orbilogin.com/online_upgrade_info.html.
Try forcing Orbi to use static IP address by assigning it an reserved IP address. Here is an example of my AP staic IP/DNS.
