Trusted_Whitey
Jul 20, 2018Aspirant
Orbi App in Access Point Mode
Is it possible to use the Orbi app when the router is just in access point mode and using a non-netgear router? I would just like to be access the Wi-Fi settings
ciacci
Nov 25, 2018Aspirant
Hi sorry but i was forced to switch to router mode due to a fault on the other router... now the mobile app works fine
in any case previous set up was: AP mode - dynamic IP or fixed nothing change - only acces wia web based app with direct IP connection, no chance to use the mobile app
Now switching to router mode the app connect flawlessly
thanks
Steven_Belfast
Nov 26, 2018Apprentice
By any chance was the other router that was in use also a Netgear ?
- ciacciNov 26, 2018AspirantNo was an old pro router from tp-link TL-R600vpn with dhcp on
- Steven_BelfastNov 26, 2018ApprenticeI am stumped đ€
- Steven_BelfastNov 27, 2018Apprentice
My configuration is a little random đ
Have my ISP provided router going via Ethernet to Orbi set up in Ap mode.
From Orbi it goes to a 8 port managed switch in another room.
The Orbi Satellite in also in another room using wireless back haul.
Main router has ip of 1.253
Orbi manually set in Orbi to 1.252
Switch manually to to 1.254
Both switch and Orbi have DHCP off
I have other Netgear Nighthawkâs that I tested the Nighthawk app on and connected to switch in Ap mode they also worked as long as I was connected to the right ap was able to use both apps with no problems.
