growly
Jan 14, 2021Tutor
Orbi changed its password
A week after our Orbi's web interface turned sluggish, failed to load some pages, and then bricked itself, I am now locked out of the device. I know the password is the correct one since it's the...
Jan 14, 2021Guru - Experienced User
A factory reset will not brick or impact anything aside from loosing your user configureation and would be a valid test to do.
What version of FW are you using currently? Mines on v102 and have not see any problems at the RBR or this "bricking" on it's own.
v2.7 versions are for users in the US region, v40 is the most current version for all other regional users.
growly
Jan 14, 2021Tutor
FURRYe38 wrote:A factory reset will not brick or impact anything aside from loosing your user configureation and would be a valid test to do.
A factory reset shouldn't brick anything, but for example all of my problems could be explained by bad nvram in the device, which would cause problems from memory corruption (password failure) to failure when resetting (backup image corrupted). Of course, that would be a disaster, 3 months out of warranty.
I use v102 like yourself. I'm guessing I'm the only one with this problem then :(
- FURRYe38Jan 14, 2021Guru - Experienced User
Well, avoiding the problem won't help either. Maybe a time bomb ready to go off as well and if a power bump hits it, then anything could happen there as well. You can keep on using it or you may want to take more proactive steps and find another RBR or something else to put in it's place. I would not want to hang my total operation of the RBR on not knowing if the RBR is beginning to fail. If there is any kind of doubt about the RBR, you shoul get it resolved sooner then later.
Good Luck.
- growlyJan 14, 2021Tutor
FURRYe38 wrote:Well, avoiding the problem won't help either. Maybe a time bomb ready to go off as well and if a power bump hits it, then anything could happen there as well. You can keep on using it or you may want to take more proactive steps and find another RBR or something else to put in it's place. I would not want to hang my total operation of the RBR on not knowing if the RBR is beginning to fail. If there is any kind of doubt about the RBR, you shoul get it resolved sooner then later.
Good Luck.
Thanks, and you're right. If only I could undo my purchase of this expensive garbage (I already had to replace 1 satellite).
I tried following the reset procedure but after typing in my unit's serial number I get "400 Bad Request". This is exactly what happened before it bricked itself the last time I factory reset:
