Proton68
Feb 13, 2019Aspirant
Orbi connection to China
Hi,
I've upgraded my IPS system and it has begun to send me alerts notifying that my orbi device was connecting on port 80 to an address that seems to be in China, and it does so regularly. doe...
CrimpOn
Feb 14, 2019Guru - Experienced User
The WhoIs lookup on these IP's traces back to:
inetnum: 203.205.192.0 - 203.205.255.255 netname: TENCENT-NET-AP descr: Shenzhen Tencent Computer Systems Company Limited descr: Tencent Building, Kejizhongyi Avenue,Hi-techPark, descr: NanshanDistrict, Shenzhen country: CN
inetnum: 203.205.128.0 - 203.205.159.255 netname: TENCENT-NET-AP descr: Shenzhen Tencent Computer Systems Company Limited descr: Tencent Building, Kejizhongyi Avenue,Hi-techPark, descr: NanshanDistrict, Shenzhen country: CN
This doesn't smell like "Netgear" to me. If 10.1.1.16 is the Orbi's WAN port, you could use the debug page to capture the LAN traffic and see exactly which device on your Orbi is connecting to those IP's.
JoeCymru
Feb 15, 2019Virtuoso
Personally I would be concerned and not about Orbi. Tencent is the largest social gaming company on earth and also has an instant messaging service. Port 80 traffic to tencent could be worm or trojan utilizing one of your devices to try to hook up for fraudulent purposes.
- CrimpOnFeb 15, 2019Guru - Experienced User
Once the connection is traced to a specific device, the next step may be to determine which app on that device is opening the connection.
- michaelkenwardFeb 15, 2019Guru - Experienced User
To help to home in on this excellent suggestion, in the past there have been references to devices like IoT cameras and other cloud connected widgets. They make a lot of those in China!
I don't know if it matters whether the Orbi is in "router" or "AP" mode (my Orbi is in router), but @ekhalil showed me how to display all the "open ports".
Browse to the Orbi debug page, usually 192.168.1.1/debug.htm
Check the box "Enable Telnet"
User your favorite telnet application to telnet to the Orbi and log in with the same "admin" and password
Enter the command cat /proc/net ip_conntrack
It is sort of tedious to locate the IP you want in the telnet window, so I save the telnet session to a file and use a text editor to find what I want, sort the entries, etc. Every time I used the Windows telnet client, I would forget to save the session to a file, so I changed over to Putty and created a script that always saves the session to a unique text file.
After closing the telnet session, remember to go back to the debug page and turn off telnet access.
Once the device which has opened that IP connection has been located, I believe there are similar commands to display which application has the port open.
