kelvin1128
May 24, 2017Tutor
Orbi cut my speed in 1/2
I currently have Verizon Fios gigabit internet, when I connect my laptop via Cat5E directly to the Fios Gateway, I get about 800 mbps. However when I do the same speed test right next to the "home ba...
- May 24, 2017Try to go to the QOS settings in the advance tab run speed test there. See if that reset anything. If not u can try to disable the QOS to see if it help. Orbilogin.net/QOS_main.htm
OrbiMan
May 24, 2017Luminary
- kelvin1128May 25, 2017Tutor
Thanks OrbiMan the speed test from qos setup shows a little better speed, around 500 mbps but still slower than directly from fios gateway
