thebishop
Feb 01, 2017Apprentice
Orbi drops wifi for iPad Pro, iPhone 7 and Macbook Pro intermittently
Running 1.4.0.34 on both main Orbi and sattelite (main and sattelite are on different floors with wall between, perhaps 20-25 feet distance straight line). I generally have "5 bars" of Wifi on al...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
DrCal
Jun 10, 2017Star
I have beta FW V1.10.1.4 installed for both RBR40 router and two RBS40 satellites. So far so good in terms of WiFi connection to iDevices...
ikjadoon
Jun 11, 2017Star
Can I ask the scary question? How is the backhaul? Does it yoyo from -110 to -xx?
I only ask because there's a fear that small intermittent drops might not register as disconnections in the WiFi status symbol (but are noticeable in real-time communication like Skype) or maybe clients (that are close enough) rapidly connect to the router's SSID during the dropouts?
I don't know if the backhaul is the be-all end-all, but it might be a positive sign. No worries if you aren't able; I'm only curious.
- DrCalJun 12, 2017Star
Frankly I have no idea what backhaul is and how to measure it, but am willing to try when I get home tonight. I believe I saw instructions in this thread somewhere...
