mgeorgy
Dec 15, 2017Tutor
Orbi Ethernet Backhaul causing broadcast storm
I have just upgraded my Orbi router and satellites to V2.1.1.12 hoping to take advantage of the recent Ethernet backhaul feature. I use the Orbi router as my main router with a 24 port switch servic...
turnerm05
Dec 19, 2017Luminary
tcommander Eero supports wired backhaul. Originally this wasn't supported but now it is. I'm running two of my units (gateway and one other) on a wired backhaul connection with 3 other units running wirelessly. Performance has been flawless.
I wish the Eero units had more ethernet ports on the back but this is easily solved with a cheap switch.
The Velop system should work well for you though - best of luck!
tcommander
Dec 19, 2017Guide
turnerm05 I thought I read the Eero router came with ethernet ports but that their sattelites were called beacons and that they did not have ethernet ports? Did I read wrong / misunderstand pertaining to Eero Gen 2?
- turnerm05Dec 19, 2017Luminary
@tcommander They have two main products that come packaged in multiple different ways but basically, they have a puck style unit that has two ethernet ports and they have beacons which plug direction into a power outlet that have no ethernet ports.
You can buy the Eero pro package which comes with three pucks. Or you can buy a package that comes with one puck and two beacons. Or you can buy a package that is one puck and one beacon, etc...
I bought the Pro package and then bought a package with one puck and one beacon. The beacons are nice in certain situations but I definitely prefer the pucks in most situations.
Their packaging can be a little confusing but if you want ethernet ports, stick to the pucks.
