JMU1998
Nov 25, 2016Luminary
Orbi Firmware 1.4.0.16
Looks like new Firmware just released today 1.4.0.16 anyone taken this yet? I will as soon as I get some time today hopefully it address frequent random wireless drops.
dpdurst
Yep just upgraded, guest network access is now available that is the first thing that stands out along with adding another Orbi satellite to the system.
Under advanced wireless settings, I don't recall the wireless stuff and resetting the backhaul password to be there before was it?
Dave_G20
Nov 27, 2016Aspirant
I am looking for an image file for the RBS50 for the 1.4.0.16 update (Just got the thing). The RBK router updated to 1.4.0.16 and the satellite is an epic fail (won't update from the stock 1.1.0.16 version). The firmware link on the site is just the 1.3 version leaving me high and dry. Any idea where I can 1.4 for the RBS?
- peteytestingNov 27, 2016Hero
hi
you need to update the sat/s to 1.3 first and then it should then show you the 1.4 software available for the sats
- Dave_G20Nov 27, 2016Aspirant
It won't let me upgrade to 1.3 (since the RBK is at 1.4) It tells me invalid firmware
The exact message is "This firmware file is incorrect! Please get the firware file again and make sure it is the correct firmware for this product."
The file is RBS50-V1.3.0.26.img directly from the Netgear site.
try rolling back the router to 1.3 and then manually installing the 1.3 on the sats manually and then do the update to 1.4
do it offline to get everything to 1.3 first then connect the orbi router to the internet and it should the auto update it all to 1.4
