MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Licorice1978
Oct 23, 2019Initiate
And the setting for different SSID has been gone and can't be set again.
MikeG63
Oct 23, 2019Apprentice
So 6 bugs fixed, 2 new ones and counting :smileylol:
Also wrt - [New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
Hmmmmmm......did something there to break it as well!!!
