MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Oct 30, 2019Guru - Experienced User
Ok, thanks for letting us know. Yes latest FW is good and does work. Again, some users need to factory reset and setup form scratch. I would also power OFF the modem for 30 seconds as well while the RBR is being reset. This should help resolve your issues. After getting it setup again, do a backup configuration and save to file. This will save you time should a reset be needed later on down the road.
mtowle wrote:For security reasons. In my opinion, it's always good to be running the latest firmware to get the latest security vulnerability fixes. By the way, my cable modem does not have a built in router. Thanks!
dnonnema
Oct 30, 2019Aspirant
I bought mine in Sept, and had massive connectivity problems until a NG tech advised me to upgrade the FW. once that was accomlished, all was good.
I was hesitant to upgrade again, but I upgraded to 2.5.0.38 last week without any problems.
Question how do I back up the configuration? I have a feeling I will need to jump through hoops with the next FW update.
