Walkmic3
Oct 17, 2017Guide
Orbi Losing wifi connection
I have had the Orbi AC 2200 for a month now. 2 to 3 times a week we completely lose our wifi.
Jun 08, 2018Guru - Experienced User
Has a reboot of the system been performed?
So your streaming music using this system thats all lan wired to your PC or AVR?
Is the music system and other wired devices connected all to the back of the router?
Is there a network switch in the mix? If so, what is the Mfr and model of this switch?
You might try a factory reset of the router and set it up from scratch.
kavpaul wrote:
Hi there
I probably didn't explain correctly but the music system is all conected via ethernet and not wifi.
My firmware version is V2.1.4.10
The music system is by Bluesound
My Orbi is connected to the latest Virgin Media Hub 3 which is setup in modem mode only.
The Orbi Router is connected to this via Cat 6 ethernet cable and is acting as my main router.
I have two satellites connected of this Orbi Router. My house is over 3 floors and wifi coverage from these is quite good.
The problem which is surprising is on the ethernet connection and not wifi. No problems with it previously.
Regards
Paul
kavpaul
Jun 08, 2018Guide
A reboot has now been performed as the system is only newly setup. Resetting and doing from scratch again is a pain considering I have only just set it up from new !
The router has ethernet out to my switch which is routed to the various items in the house.
In the last few mins I have removed the wired backhaul of the Orbis and put them back to using wifi. Not sure if that will help but I will monitor.
I have two gigabit switches in the system. One by D Link and the other is a Linksys unit. No issues with them before so I dont expect they have anything to do with it.
If it dosen't start resolving itself I am going to return it. Nearly £500 spent on it and I don't want these sort of issues or challenges from the system.
- FURRYe38Jun 08, 2018Guru - Experienced User
what is the model of this switches?
- kavpaulJun 08, 2018Guide
Linksys LGS 108
The D Link is too hard to access but is very stable and relaible.
Funny since I removed the ethernet backhaul in the last hour from the Orbi system it is appearing far more stable. One of these was set up over powerline and the other through the Linksys Switch.
Could that have been the issue?
Possible. Possilbe also that your switches could be Managed switches? You'll need to check with the Mfr of these switches to confirme they are managed or non-managed. Other users have posted about issues with manages swiches. Something having to do with IGMP protocol being enabled in them. Disabling IGMP was resported as a fix with managed switches.
Remove the switches and PL and try to test with a satellite directly connected to the router.
kavpaul wrote:
Linksys LGS 108
The Linksys Swiitch is NOT managed but I can't be sure about the D Link so I will swap that out for another Linksys unmnagaed switch
Leave it with me and I can update again
