Walkmic3
Oct 17, 2017Guide
Orbi Losing wifi connection
I have had the Orbi AC 2200 for a month now. 2 to 3 times a week we completely lose our wifi.
Jun 08, 2018Guru - Experienced User
Possible. Possilbe also that your switches could be Managed switches? You'll need to check with the Mfr of these switches to confirme they are managed or non-managed. Other users have posted about issues with manages swiches. Something having to do with IGMP protocol being enabled in them. Disabling IGMP was resported as a fix with managed switches.
Remove the switches and PL and try to test with a satellite directly connected to the router.
kavpaul wrote:
Linksys LGS 108
The D Link is too hard to access but is very stable and relaible.
Funny since I removed the ethernet backhaul in the last hour from the Orbi system it is appearing far more stable. One of these was set up over powerline and the other through the Linksys Switch.
Could that have been the issue?
kavpaul
Jun 08, 2018Guide
The Linksys Swiitch is NOT managed but I can't be sure about the D Link so I will swap that out for another Linksys unmnagaed switch
Leave it with me and I can update again
