AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
 Let me give you a quick update on the status since the last time we posted.  Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018Check out this post for an update on this issue: https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
DerAusgewandert
Mar 16, 2018Star
hmm, reading all these negative posts I'm betting paranoid that I might end up in the same situation. Currently I have no issues. I am not using the backhaul feature - which is likely the main reason for not having issues. I have one day left to return it and get a Velop instead. I am torn....I might need that backhaul eventually.
It seems those of you who switched believe you've made the right choice. The evidence in better customer support and warranty seems to speak for a switch. There has been no update since the OP on the subject, while it sounded like they are close to a solution. Maybe tomorrow I'll be throwing dice.
mpf541
Mar 17, 2018Apprentice
I also had no problems for 9 - 10 months. And then they added more features. And then the disconnects started.
They must be aware of this as they only want to give 90 days of support before you have tp pay.
