AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
Let me give you a quick update on the status since the last time we posted. Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018
Check out this post for an update on this issue:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
Starbucky
Mar 18, 2018Apprentice
Actually the speed of the interface for Circle doesn't realy make a difference. Latency would be more of an issue (wifi more latency vs wired). The Circle device is not an inline component so traffic does not go through it. It works by highjacking the DNS requests for managed devices through ARP cache poisoning. It does increase the broadcasts on the LAN and uses very little WAN bandwidth fromwhat I can tell. It doesn't have much impact on performance.
I bought a Velop 3pk and Circle box yesterday and have been doing lots of testing. The initial setup was very similar to Orbi and similar amount of time. I'm only using one satellite (wireless backhaul right now, i will test wired also) at this point to better compare the Velop to the Orbi RBK50. I placed the router and satellite in the same spots I had the Orbis. It took a while to reconfigure all my cams, home automation stuff, streaming devices, tablets, phones, etc.. 30+ devices, not counting PCs . I used the Speedtest app on my iPhone 7 in every room of the house and indeed the Orbi is usually faster. The roaming is similar for both brands (seemingly for iOS clients). It will maintain connection with the current node and drop to 2.4G when the second node is closer and a 5G connection would be possible.
This is day two so I can't comment on stability (dropped connections or internet). The Velop forums also show users having dropped connections and reboot issues so it suffers from similar issues the Orbis are having with the latest FW. Velop owners are also saying that speed gradually decreases over time and reboots are required to restore speed. I haven't seen that issue in the Orbi forums. Anyway things aren't that much better on the Velop issues side, alot of angry postings there too about the amount of time being taken to resolve issues.
My initial feeling is that I may actually stick with the Orbi. I've had a couple of issues with it with dropped wifi connections and one reboot in three weeks. I just fear regretting it later on. One of the major reasons, funny enough, is that the Velop web interface sucks, no advanced config, no stats, no VPN solution, logging, etc. The devices page is nicer in a way but devices frequently show as being offline (long time issue for Velop). Other little things too, way too basic. The iOS/Android app however is better IMO than Orbi's. Mind you not by much. They're both lacking.
Anyway I'm going to keep testing the Velop. I have 5 days left to return the Orbi.
I'm still hoping the moderators/engeneering will provide me the 2.2 beta but no one is getting back to me...
DerAusgewandert
Mar 18, 2018Star
strange, I posted a reply and my post disappeared...
Starbucky, I can confirm your findings.
I tested a Velop (2pk) side by side with the Orbi and the bottomline is that the Orbi is better in handling roaming clients. The connection on the Velop would go down to fair with very weak signal before it switched me over to the next node which was right next to me. It then switched to the 2.4GHz rather than the 5GHz as well. Lots of spots in the house with bad signal because of that. Under identical conditions with the Orbi, I never lost the 5GHz connection and the signal is always excellent throughout the house, seemlessly switching between nodes. Sure enough, this is one of the hotter topics in the Velop forum with a number of users with that exact problem - not even mentioning other threads with internet connection issues. Lots of angy users, just like here.
I will probably stick with the Orbi and return the Velop. I will test this one more time. Overall the signal and client handling seems to be much better on the Orbi - at least in my house.
cheers
- StarbuckyMar 19, 2018Apprentice
Good day DerAusgewandert,
I totally agree. I did some thorough testing with one satellite to compare to the Orbi and then added the second Velop satellite last night in our upstairs hallway. Adding the second satellite took over an hour, it just wouldn't complete sinking and kept telling me to bring it closer to the router... I ended up having to basically put it right next to the router. I rebooted the entuire system a couple of times to see if my various devices would connect to their nearest satellite and they just wouldn't. I have 7 Dlink cloud cameras and they didn't connect to their nearest AP and worst of all a basement camera insisted on connecting to the second floor satellite with barely any service making it essentially non functional. As I sit at work this morning two of my other cameras aren't connecting remotely. I also have 5 Chromecast Audio throughout the house and all of them connected to the router rather than their closest respective satellites. Those are some of the stationary devices. Our phones and tablets also wouldn't roam well at all. I tried wired backhauil too and it didn't make any difference, in fact it messed up the devices page identifying all wired clients as connected to one of the satellites when they are in fact connected to a gigabit switch on the router... All said, in my case the RBK50 2pk is much better than Velop 3pk. I'm packing up the Velop tonight and re-installing the Orbi, keeping my fingers crossed that I continue to have minimal issues.
Cheers,
- mpf541Mar 19, 2018Apprentice
I have been experimenting with a velop. So far all is working properly and I do connect to the closest node. I did notice this did take some time for this to work correctly. As the setup is all done wireless and after I moved to the correct place in my house and used wired connections. I had to renew connections from some devices to get them to switch to the closet node. Not sure if swicth while roaming i will have to test that later. But I have not noticed any problems from where devices are. There is not much roaming from room to room.
But I really hope that netgear is close to a solution for the orbi. i do have a long return policy as i got directly from linksys. Hmm that return policy is as long as netgear gives for tech support. maybe netgear should look into customer safisfaction. As I am not satified that my orbi does not work right.
- wildhorseMar 19, 2018Star
So it looks like Velop is an inferior product after all.
I have had no major issues, except for one minor problem - satellite having lots of active network sessions (3198/65536) even if unused - visible on satellite debug page. I reported that. But it does not affect stability in any way.
- DerAusgewandertMar 19, 2018Star
Starbuckywrote:Good day DerAusgewandert,
I totally agree. I did some thorough testing with one satellite to compare to the Orbi and then added the second Velop satellite last night in our upstairs hallway. Adding the second satellite took over an hour, it just wouldn't complete sinking and kept telling me to bring it closer to the router... I ended up having to basically put it right next to the router..................... All said, in my case the RBK50 2pk is much better than Velop 3pk. I'm packing up the Velop tonight and re-installing the Orbi, keeping my fingers crossed that I continue to have minimal issues.
Cheers,
I gave the Velop another chance all day today and let it "work itself in". It didn't change/improve. Maybe I got a bad unit, but looking at posts like yours and the posts on the Linksys forum, this seems to be a more common problem. I am packing it up as I type and it's going back tomorrow. I have the Orbi back on and in my environment the Velop is simply not working well.
- ktoonsezMar 20, 2018StarI also tried the Velop before the orbi. I had nothing but problems with it. Constant disconnects, Alexa had problems connecting to the Internet all the time and my smart switches would always end up being unresponsive trying to use Alexa commands. Pnce I switch to orbi all those problems went away.
