AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
Let me give you a quick update on the status since the last time we posted. Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018
Check out this post for an update on this issue:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
Mar 20, 2018Guru - Experienced User
There ya go.
What is the current distance between the router and Satellite. Mines about 40 feet. Not sure how much farther I can go in range. Mines currently on wired back haul.
Let us know how it turns out.
DerAusgewandert
Mar 20, 2018Star
Mine is more than 40feet. 45feet is the projection and then it's an additional 10 feet in the vertical because the satellite sits in the hallway of the second floor. There is a wall and a stairwell and ceiling in between. I had concerns when setting this up initially, but so far I have had no problems at all. Excellent signal throughout the house. I'm not using wired backhaul.
