AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
mealto
Mar 24, 2018Star
Running this for almost 12 hours and all is good. For now, every 1-2 min, I see this in the logs:
[DoS Attack: IP Spoofing] from source: 192.168.1.254. Don't see any attached devices to the router or satellite with this IP.
Any idea what this may be?
DerAusgewandert
Mar 24, 2018Star
mealtowrote:Running this for almost 12 hours and all is good. For now, every 1-2 min, I see this in the logs:
That is possibly your ATT Gateway (2Wire or Arris) that is pinging your router. I have the same thing. If your ATT Gateway is set up to block DOS attacks or filter pings then you can disable that on the Orbi (although you should have your Orbi set to DMZ on the Gateway and disable most of the filtering and let your Orbi handle all that).
cheers
