AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Mar 25, 2018Guru - Experienced User
I'll give this try soon as I get a chance this weekend.
mealtowrote:
FURRYe38wrote:Yes seeing same thing with Wifi Sweetspots, ranging from 300 to 400+Mb. I presume this is between device and router only and not ISP services.
Looking at the About info, its seems only to find spots in the room best for your routers and such. So, ya, only between the mobile device and router. Which speed if your close will be high and are also testing max speeds of your mobile device as well.
Did you try running Wifi Sweetspots while connected to satellite versus router? If so, compare it to my numbers and see where we stand.
Supertramp11
Mar 25, 2018Luminary
Upgraded my RBK50 from V2.1.2.18 to V2.1.3.4 and now I'm facing poor backhaul connectivity.
Any suggestions from this community?
PS. The router and satelite have not moved location.
- b1ggjoeMar 25, 2018ApprenticeYep:
- Make sure you upgraded the Firmware on both the Router and the Sat.
- If you did, perform a factory reset on just the Sat and see if that helps.
- If not, then also perform a factory reset on the Orbi Router as well. - Supertramp11Mar 25, 2018Luminary
Thanks for your reply.
I have not done a factory reset. Will do that and report back later...
Factory resetting the satelite did the trick. Backhaul connection is good again.
Thanks!!!
- JoechangMar 25, 2018Apprentice
Supertramp11 same here, i have tried disabled fast roaming / beforming and daisy chain, finally found that disable fast roaming and Mu-MIMO makes backhaul good again.
before fast roaming/beforming and mumimo are all on and backhaul was good
