AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
b1ggjoe
Mar 25, 2018Apprentice
Yep:
- Make sure you upgraded the Firmware on both the Router and the Sat.
- If you did, perform a factory reset on just the Sat and see if that helps.
- If not, then also perform a factory reset on the Orbi Router as well.
Supertramp11
Mar 25, 2018Luminary
Thanks for your reply.
I have not done a factory reset. Will do that and report back later...
- Supertramp11Mar 25, 2018Luminary
Factory resetting the satelite did the trick. Backhaul connection is good again.
Thanks!!!
