AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
wchp
Apr 04, 2018Luminary
DezMwrote:When are you guys finally going to support hard drive or flash drive support on the USB port? Would love to stream media off of it via ReadyShare
This kind of thing tends to get lost in a thread like this. Start a new post and Title it FEATURE REQUEST and then others will give it a Thumbs Up to support the idea.
I just started a new one for a radio button to disable automatic firmware updates. See here: https://community.netgear.com/t5/Orbi/FEATURE-REQUEST-Ability-to-DISABLE-firmware-auto-update/m-p/1544862#M27364
DezM
Apr 04, 2018Star
I have in the past (Aug, 2017) only to get generic response and null response from Netgear. I'm still waiting and directed my question to the OP AmitR who appears to work for Netgear.
- FURRYe38Apr 04, 2018Guru - Experienced User
What generic response did you recieve?
DezMwrote:I have in the past (Aug, 2017) only to get generic response and null response from Netgear. I'm still waiting and directed my question to the OP AmitR who appears to work for Netgear.
- DezMApr 04, 2018Star
"It may or may not come in future updates".
Love the system. It just works here in my home but miss the ability to stream media off my USB connected drive via ReadyShare. I've owned Netgear & Linksys routers that offered this support
I know, other Mfrs have this. Not sure what thinking was behind not having this feature for users. I'm sure there is some security reasons behind it. Still, rather have the abililty to choose. :smileyfrustrated:
