AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
guzzijason
Apr 04, 2018Apprentice
FURRYe38wrote:Yes this is a beta. Some received this via auto update.
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584/highlight/true#M26234
Was probably mistakingly put up on the auto update servers. It's been removed. Please do a factory reset on the Orbi system and set up from scratch if you haven't already.
No, it was deliberately added to auto-upgrade. Seems like it was promoted to GA to me:
AmitRwrote:I can confirm, we've begun pushing 2.1.3.4 available for auto-upgrade. Feel free to upgrade using mobile app / WebUI.
Orbi Product Management
OrbiMan
Apr 06, 2018Luminary
I check my update it is not there
- FURRYe38Apr 06, 2018Guru - Experienced User
https://community.netgear.com/t5/Orbi/Is-2-1-3-4-in-auto-update/m-p/1546170/highlight/false#M27518
