AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 12, 2018Guru - Experienced User
Please try the factory reset and set up from scratch for this version of FW. This is needed for this version. Once official next version is released, and all subquent verions shouldn't need a factory reset. Let us know how it goes after the reset.
aucman wrote:I am experiencing the same trouble. Devices connected to the router are working fine. Devices connected to the Satellites are losing connection or appears everything is fine and there is no internet connection.
The problem is the satellite not the router. I had similar trouble on firmware 2.1.2.18 and installed 2.1.3.4 and it is still the same issue.
However I did not do the factory reset before installing firmware 2.1.3.4
OrbiMan
Apr 12, 2018Luminary
FURRYe38 wrotePlease try the factory reset and set up from scratch for this version of FW. This is needed for this version. Once official next version is released, and all subquent verions shouldn't need a factory reset. Let us know how it goes after the reset.
Where did you get that info?
