AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
wchp
Apr 20, 2018Luminary
turns2stone wrote:After several reboots of everything, I was able to get wired backhaul working via direct connection from satellite to router. Now I've moved the satellite back to it's main home/room. Only a single switch in between the router and the satellite, but I still cannot get it to work again.
Just a thought... have you tried power cycling the switch so it rebuilds its arp table?
turns2stone
Apr 20, 2018Apprentice
No, but that is a great idea. Will try.
FURRYe38 wrote:
Possible cabling between the router and satellite and or this switch. If it worked directly connected to the router using different cableing, Then you'll need to check cabling and this switch. Which switch are you using here?
Switch is D-Link DGS-1024D, cabling is all Cat6 solid core UTP, never had an issue before.
