AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
steve8411
Apr 18, 2018Apprentice
It is a firmware issue.
You can factory reset till your paperclip turns to rust .... turn on/off whatever feature till your mouse battery dies... Ain't gonna solve anything.
Engineering has to fix the problem ....
wchp
Apr 19, 2018Luminary
Just to be clear... When you reset your Router and Satellites with a paper clip, the user has to hold the reset button until the orange light starts blinking.
I only mention this because in another discussion another user thought the LED on the back only had to turn orange and didn't realize they had to continue holding in the reset button until the LED was BLINKING orange for a full reset.
steve8411 wrote:You can factory reset till your paperclip turns to rust .... turn on/off whatever feature till your mouse battery dies... Ain't gonna solve anything.
