AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
steve8411
Apr 20, 2018Apprentice
My iPad 9.7 was the main culprit having the same issue...
This firmware makes it better, but it still happens (requiring a cycling of wifi on the iPad). Just happens less frequently.
I also noticed with this beta, the battery on the iPad lasts much longer on Wifi ... have you noticed this yet turns2stone ???
turns2stone
steve8411 wrote:My iPad 9.7 was the main culprit having the same issue...
I have noticed any difference in battery life/performance with this firmware and my iPad Pro 9.7, but I haven't really been paying attention.
- JeremyinsfApr 21, 2018Apprentice
I agree it still happens but not as frequently.
And battery life is degraded as devices are searching and reconnecting to networks. So if it doesn't have to do that as often, and it's reliable and stable, battery life will be better.
