AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 23, 2018Guru - Experienced User
How long did you wait before checking the network. 5 minutes should be long enough.
Reason for trying a long cable is to see if remote location with long cable works vs your installed cable infrastructure.
If the Satellite is working directly, then not in it's remote location, this means something in between is a cause or causing the satellite not to work right or mis operate. This points to a cabling problem between the remote location and router.
turns2stone wrote:
FURRYe38 wrote:IF the satellite wired back haul is working directly conntect to the router with just a LAN cable in between for this test, it should work at its remote location. Only items that would impact this is faulty cabling in between, connectors, or managed switches. Need to rule out each one and try to narrow down where the Satellite is failing when it's placed in his desured remote location...
If you get it working in the temp location directly to the router for wired back haul, then power OFF, place in remote location and power ON, it should connect in the same wired back haul and not need any reconfiguration. Should just work if the cabing and connections are good in between.
Happen to have a long lan cable that you can temporarily run between the router and remote location?
I can tell you that wired back haul is working in this FW version.
I agree that it *should* work, when I power off the satellite and move it to it's regular location and reconnect Ethernet. Not sure what a long LAN cable to the regular would accomplish? I realize you got it working, and appreciate the help. But based on how just plugging in a LAN cable to a satellite can bring down the whole network, I don't think wired backhaul is very stable at this point.
turns2stone
Apr 23, 2018Apprentice
FURRYe38 wrote:How long did you wait before checking the network. 5 minutes should be long enough.
I waited at least 30 minutes. I guess I still don't understand the long cable suggestion. If it works via a "short" cable, of course it's going to work if I use a 50ft cable and just move the satellite to another room away from the router.
I still hesitate to believe it's a cable issue. I've tried wired backhaul in 3 different rooms, with two different satellites. Other network devices negotiate full duplex 1000Mbp/s when connected to the same LAN jack that I'm attempting to use with the Orbi satellites. I've tried a variety of patch cables, all "new" quality Cat6 cables from Belkin, etc.
Also, I forgot to mention.. direct connection of the satellite to to the router does not work 100% of the time. Maybe 50%? Which again is why I think there is something inherent to the firmware that chokes on Ethernet backhaul based on certain circumstances.
- FURRYe38Apr 23, 2018Guru - Experienced User
5 minutes is all thats needed after conneting the cable to the satellit. If its longer and your not seeing the BLUE LED at the top, then something is wrong.
Long cable should simulate whats in the walls and such. I'm trying to establish with your satellite that it if it works short cable in temp location, it will work in remote location with longer cable. If so then this isn't a satellite or FW issue, this is a in wall infrastructure issue that needs to be reviewed. Cable continuity and connections should be tested and checked fully.
I don't recommend anything Belkin...your choice though. I get most of my cabling from either DeepSurplus or MonoPrice.
- turns2stoneApr 23, 2018Apprentice
FURRYe38 wrote:Long cable should simulate whats in the walls and such. I'm trying to establish with your satellite that it if it works short cable in temp location, it will work in remote location with longer cable. If so then this isn't a satellite or FW issue, this is a in wall infrastructure issue that needs to be reviewed. Cable continuity and connections should be tested and checked fully.
OK, fair enough. I have tested cable continuity for all my drops. Belkin is just an example, I have dozens of patch cables, as I'm sure many of us do :)
I forgot to mention.. direct connection of the satellite to to the router does not work 100% of the time. Maybe 50%? Which again is why I think there is something inherent to the firmware that chokes on Ethernet backhaul based on certain circumstances. Or the backhaul doesn't like going through my switch, in particular.
Can you post your switch model# again, I don't remember which one you had. Possible that this switch could be an issue. This is one reason for doing the long cable between the router and satellite.
Do you have more then one satellite that you can test with? You might swap satelites if you have more than one to test directly connection stability. It's possible that you have a bad Satellite and or bad router or system entirely aswell. If you can test with a different satellite directly to check stability. IF you seem to find that it's still not working well at this point, I would ask for a full RMA. Have them load up v2.1.3.4 and send a system out to you.
You would need to test the direct connect a bit longer if you have a long cable to see if the remote location exhibits the same 50% issue. Just seems that you are getting more results with direct connect then you not getting any connections with in wall cabling, switch and orinfrastrucure. This points to something in this area.
- turns2stoneApr 24, 2018Apprentice
FURRYe38 wrote:Can you post your switch model# again, I don't remember which one you had. Possible that this switch could be an issue. This is one reason for doing the long cable between the router and satellite.
Main switch is D-Link DGS-1024D.
I spent several hours testing tonight, and I'm giving up - with this firmware, at least.
I do have two RBS50s to test with. Occasionally, I'll plug a LAN cable in, and the router GUI will still show 5G backhaul, this is even after 10+ minutes and a reboot. Sometimes I'll move a satellite to a completely different room/LAN drop, plug it in, and the LAN will crash, taking both RBS50s offline (magenta) as well as knocking out my RBS50Y.
Anytime plugging in (different) LAN cables in can knock out 2 other satellites, we're talking a serious firmware issue here.
- FURRYe38Apr 24, 2018Guru - Experienced User
Maybe, maybe HW as well. Not everyone is having LAN backhaul issues. Even with managed switches, one user said he disabled IGMP protocol on the switch and is now working. I for one have a working LAN back haul system here with two non manged switches.
Your 1024D has the following features:
D-Link Green Features
• IEEE 802.3az Energy Efficient Ethernet (EEE)
• Link status detection power savingPossible that this could be a factor as well. You would have to find a non managed swtich with out any of these features to testl. Both of my swtiches are just normal standard non managed switches with out any energy saving features.
So, v2.1.4.x seems to be looming soon. Why not give that a try and see how it does when it becomes available. I would go thru the motions of upgrading and doing a factory reset on both router and satellite to give it a good chance after insstallation. If it still exhibits the same problem after that, I think you'll need to ask NG for a RMA.
Up to you.
Be advised there is newer v2.1.4.10 FW now for 50 series systems:
https://kb.netgear.com/000055985/RBR50-RBS50-Firmware-Version-2-1-4-10
Up to you if you wanna try it.
turns2stone wrote:Main switch is D-Link DGS-1024D.
