AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
UnhappyOrbiUser
Apr 23, 2018Star
AmitR wrote:BETA MR 2.1.3 software can be found here:
RBR40: http://files.netgear-support.com/go/?a=d&i=NWHSwvM06n
That link does not work, or no longer works, whichever.
2.1.2.18 + 2.1.2.2 (RBW30) has been a nightmare.. is there a newer version I can try somewhere, or should I look for an older version?
b1ggjoe
Apr 23, 2018Apprentice
Hey Everyone,
I have a RBK50 system that has been performing flawlessly since the day I installed it. I'm using the following Firmware: V2.1.2.18.
Does this Firmware support Ethernet-Backhaul? I haven't tried it yet, so just wanted to ask before I do.
Thanks!
BJ
- FURRYe38Apr 23, 2018Guru - Experienced User
V2.1.3.4 supported ethernet back how. Works well. Its recommended after you update to this verions of FW, do a factory reset on both router and satellite(s) then setup from scratch. Some major changes in this version so it needs a clean slate.
b1ggjoe wrote:Hey Everyone,
Thanks!
BJ
- b1ggjoeApr 23, 2018Apprentice
Thank you Sir!! I have a small request:
I've seen so many different recommendations and 'recipes' on what is the best thing to do, as well as the specific order in which to do things, when it comes to updating/upgrading Firmware, the Router first vs. Satellites first and etc.
Would it be possible for you to throw something together that we can all use as a guide for the best way to perform Firmware upgrades and so forth?
Thanks!
BJ
You can follow this:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-Satellite
Moderators seem to want users to use this process.
The only thing it doesn't mention is the factory reset and set up from scratch. This is only needed for this version of FW that seems to need a clean slate to start from. NG normal process is to update FW wiith out having to factory reset which I presume will be back to being the normal process upon the next FW update.
b1ggjoe wrote:Thank you Sir!! I have a small request:
Thanks!
BJ
