Dumbus
Jan 20, 2021Aspirant
Orbi Network Apple Devices
Last week on Tuesday or Wednesday Hotmail login and Active directory login started being blocked on Apple Devices using the Orbi wifi network. It previously worked fine and still works fine if I do ...
- Feb 02, 2021
Dumbus wrote:I tried everything. Put Telstra Modem in bridge mode etc. Finally I found in the Orbi admin website (not on the Orbi App) that Disney Circle was enabled under the security tab. Turned it off and everything works again. Now I just need to find out why the Disney Circle App was blocking Microsoft websites suddenly. Thanks for your help
Nice
you may want to mark your post here as solved.
thank you
Dumbus
Feb 01, 2021Aspirant
vajim
Feb 02, 2021Master
Nice
thank you
