ORBIisJUNK
Jun 07, 2020Aspirant
Orbi network drops frequently and Satellite showing poor backhaul status
Hi, I have following setup RBR50 - Setup in basement RBS50-1 - Setup on the first floor which is above basement RBS50-2 - Setup on the second floor I have 500Mbps fiber optics line coming ...
Jun 08, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
denniss82 wrote:I am having the same issue. just upgraded a few days ago.
Today the connection started dropping every 60 seconds. I have tried many things already, nothing works. I have gone back to two different firmwares , I have change the wan _lease, I have changed the wires, the power adapter, hard reset a couple of times. Nothing works, Keeps disconnecting about every minute or so.
Very frustrating.
Any other suggestions?
- ORBIisJUNKJun 10, 2020Aspirant
Were you able to fix your problem? I did everything and nothing changed. It is hurting my WFH now. I moved my units and one of the Satellite still shows backhaul status poor. It is the same stellite which was showing poor earlier.
I am started getting frustrated now...
I will call NG support and update if I get something different from them.
- denniss82Jun 10, 2020AspirantORBIisJUNK
I ended up purchasing a different system, it was on clearance at Walmart for $74. Couldn’t wait anymore for Netgear to get they s..t together and fix what they messed up with the latest firmware update.
I sent a private message to a couple of people from Netgear on the forums, no one replied.
I set up the Linksys Velop system yesterday and it is running perfectly. Setup took about 15 minutes total for the three units.
https://brickseek.com/walmart-inventory-checker?sku=533132652 - ORBIisJUNKJun 10, 2020Aspirant
Thanks @denniss82!
It is not a bad option if NG doesn't fix the issue. I am trying many other things also but they are not working as of now.
Thanks!
