aellul
Mar 15, 2017Star
Orbi Performance in AP Mode
Hi all, I am currently toying around the idea of using my Orbi system in AP mode. To be honest I do not need the router functionality other than the parental controls. My service provide uses ...
JMU1998
Mar 16, 2017Luminary
I have mine in AP mode as well, the googlefiber Box is doing the routing and Orbi in AP mode is handling only Wifi functions primarily so it's resources and processing power is mostly dedicated to wifi therefore better performance.
abdu232
May 19, 2017Star
i am planning to buy the orbi 3 set but to put it on AP mode it will work good ? i can go ahad and buy it?
