fruitypigy's avatar
Feb 12, 2017
Orbi Portforwarding Not Working
I reccently got a new orbi router and have been having issues with portforwarding. I just tried making a minecraft server and everything is fine but something with the port forwarding is wrong. I use...
  • peteytesting's avatar
    peteytesting
    Jul 10, 2017
    if you are port forwarding you need to disable UPnP
