DaveElson
Oct 01, 2022Tutor
Orbi RBK -13 Streams internet fine to TV's - issue accessing internet with Win 11 PC's
Hello I have a Netgear modem/router c6300 which did not produce quite a strong enough signal in our new home. I saw the Orbi RBK-13 package at a good price on Amazon and went for it, arriving about...
DaveElson
Oct 02, 2022Tutor
When you say "attached to" do you mean using an ethernet cable? I tried the sites you mentioned - it sends me to Netgear and tells me my router is not supported. When I try to log in using the numbers it times out
DaveElson
Oct 02, 2022Tutor
I managed to log into change to AP. I will check out everything before I close this out.
Cheers.
