A316
Mar 25, 2019Aspirant
Orbi RBK 50 AC3000 Wifi speed
Hello everyone,
I need to ask what the top speed (Downloads) I can get through the wifi,because I have 750 mpbs plan and I get between 200 - 300 mpbs from my laptop and from 300 - 400 mpbs from iph...
- Mar 26, 2019
make contact with your ISP. Some Orbi systems are setup with ISP FW and can't use stock NG FW.
Mar 26, 2019Guru - Experienced User
What browser are you using? Try IE11 or FF. Besure to download the FW files and unpack them from the .zip files.
What PC are you using? Windows or Mac?
A316 wrote:
I mean the manual update It give me this message :"This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
A316
Mar 26, 2019Aspirant
I'm using Firefox.I do unpacking the files and as I told you before It didn't work.
I'm using Windows 10 and my laptop is Dell Inspiron 15 Gaming 7567.
- FURRYe38Mar 26, 2019Guru - Experienced User
What program are you using to unzip the files? Windows default should work.
If there not unpacking correctly, try re-downloading the files from the NG download site again.
Try IE11 for download...
- A316Mar 26, 2019Aspirant
WinRar
I don't have problems with unpacking.
randomousity wrote:
Also, since you're several firmware versions behind, you may not be able to update directly to the current firmware without going through one or more intermediate firmware versions. And when you download them from the Netgear site, they're in zipped files, which you have to unzip and use the binary files contained within for the updating.
Just what you said, I think I need to upgrade from pervious version, but I don't know which one to start with?
What FW is currently loaded now?
Ok, try downloading the v210 files, update the RBS first, then the RBR, then try to apply v32 to the RBS, then v212 to the RBR with finally applying v32 to the RBR lastly...
Try attaching your picture files as attached files instead of embedding them. They don't get moderated for approval fast if there embedded.
Please describe whats going on as well.
Maybe I have the same problem as this person has.
Did you get your Orbi system from Verizon or an ISP?
