A316
Mar 25, 2019Aspirant
Orbi RBK 50 AC3000 Wifi speed
Hello everyone,
I need to ask what the top speed (Downloads) I can get through the wifi,because I have 750 mpbs plan and I get between 200 - 300 mpbs from my laptop and from 300 - 400 mpbs from iph...
- Mar 26, 2019
make contact with your ISP. Some Orbi systems are setup with ISP FW and can't use stock NG FW.
Mar 26, 2019Guru - Experienced User
Try attaching your picture files as attached files instead of embedding them. They don't get moderated for approval fast if there embedded.
Please describe whats going on as well.
A316
Mar 26, 2019Aspirant
- A316Mar 26, 2019Aspirant
Maybe I have the same problem as this person has.
- FURRYe38Mar 26, 2019Guru - Experienced User
Did you get your Orbi system from Verizon or an ISP?
