BruDaniell's avatar
BruDaniell
Orbi RBK50 vs RBR50 Difference
I found the RBR50 selling the two piece set for $269, which is about $100 less than the RBK50 two piece system which makes me suspect there must be a significant difference.  Cannot find an article e...
  • AmitR's avatar
    AmitR
    Apr 17, 2017
    Correct.  You will not be able to pair two Orbi Routers together to form a system.  You need 1 Orbi Router + (1 or more) Satellites.  We do sell Stand Alone Orbi Routers and Stand Alone Satellites
