orbeefan66
Mar 24, 2018Tutor
Orbi RBR40 integration with Google Assistant
Hi, I have an Orbi RBR40 with 2 satellites Firmware shows as 2.0.0.56 with no update available. I have just set up my Netgear account to work with Google assistant and whilst I can "talk to netgear"...
- Apr 03, 2018
Managed to sort this out, slightly embarrassing really, there is remote management which I had enabled but there is also remote access which appears to be on the Genie app only. Once that was turned on Google and Netgear play nicely together! Thanks for all help and advice.
orbeefan66
Mar 25, 2018Tutor
Hi Orbi is connected to a VM (UK) router in modem mode. I linked the accounts from the Google Home app, explore, search for Netgear and add the account details. Seems to work ok connecting from Google to the Netgear account as I hear the Netgear "this is what you can do .." speech when I ask Google to talk to Netgear.
Steven_Belfast
Mar 25, 2018Apprentice
Hummm
I know I had issues first setting mine up at start and it drove me up the wall.
I have mine in AP mode linked to Sky Hub 2
Try this firmware
http://www.downloads.netgear.com/files/GDC/RBK40/RBR40-V2.1.2.18.zip
Or
http://www.downloads.netgear.com/files/GDC/RBK40/RBR40-V2.1.1.16.zip
I know others have issues with the 18 firmware but I have not had any.
Try this firmware
Or
- orbeefan66Mar 25, 2018Tutor
Thanks,I 'll give that a try, probably be next weekend now before I get time. Really appreciate the advice.
- orbeefan66Apr 03, 2018Tutor
