Paiatz's avatar
Paiatz
Guide
Jun 28, 2018
Orbi RBR50 + satellite
Hello all,   i´m using RBR50 system with 2 sattelites. I have this question: Is there a possibility to check if i´m connected over a sattelite or just connected to base station ?   thx in adv...
  • mith_it's avatar
    Jun 28, 2018
    The Orbi app should also show it. Click on a satellite and you'll see the attached devices tab
