theoak
Aug 28, 2020Luminary
Orbi RBR50 2.7.0.70 is "out"
Heard reports that this was pushed to some users.
It is available at the usual links.
Like 2.5.2.4 there are no release notes.
Orbi RBR50 support site still claims 2.5.1.16 as the official ver...
Richys
Aug 30, 2020Guide
Thats interesting. Mine is one of the original out of Costco also. I found the system was fine and stable on V2.7.0.70 also, as I previously stated, however the info on the web gui and the app were incorrect. One major one was 2.4ghz wireless was missing. It was working fine and my 2.4's were connected, however nothing existed according to app etc. The other was on the web gui the satellite's were disconnected. They weren't.
Have you by chance looked at that.
Regards
Regards
mrfranc
Aug 30, 2020Apprentice
Mine is showing each connection as it should (wired,2.4G,5G) on both app (iOS) and GUI.
- RichysAug 30, 2020Guide
- RichysAug 30, 2020GuideExcellent. Maybe now that it is showing as an update on the app, they have sorted it. Still puzzles me as to why Netgear support have not commented at all, on these forums.
I suspect that V....16 was found to have security issues and they have been trying to fix it since. Is that thought a bit off course??
Thanks also to those with the extra info re USB port.
