tagteam's avatar
tagteam
Virtuoso
Jan 25, 2024
Orbi RBR50 Dead (Wireless)
Just a datapoint. My 7+ year old RBR50 just flat out died with respect to wireless functionality.   As for ethernet, it appears to be fine. However, absolutely no wireless signal after recycles, re...
  • plemans's avatar
    Jan 26, 2024
    It is nice having a couple backups! Having 2 RBR50's sitting in a closet makes some nice redundancy. I wouldn't even working about checking into fixing the first if you had 2 backups. If the first lasted 7 years, by the time you need the other backup, it'll be time to upgrade.
