tagteam
Jan 25, 2024Virtuoso
Orbi RBR50 Dead (Wireless)
Just a datapoint. My 7+ year old RBR50 just flat out died with respect to wireless functionality. As for ethernet, it appears to be fine. However, absolutely no wireless signal after recycles, re...
- Jan 26, 2024
It is nice having a couple backups! Having 2 RBR50's sitting in a closet makes some nice redundancy. I wouldn't even working about checking into fixing the first if you had 2 backups. If the first lasted 7 years, by the time you need the other backup, it'll be time to upgrade.
Jan 26, 2024Guru - Experienced User
tagteam
Jan 26, 2024Virtuoso
plemans wrote:It is nice having a couple backups! Having 2 RBR50's sitting in a closet makes some nice redundancy. I wouldn't even working about checking into fixing the first if you had 2 backups. If the first lasted 7 years, by the time you need the other backup, it'll be time to upgrade.
100%, I agree! Funny thing is one of the RBR50 backup units I bought off a guy on ebay (private party) years ago and I thought I was buying a RBS50 (satellite) because I needed an extra SAT. When it arrived, I just didn't have the heart to send it back because it was my mistake. The other one I intended to buy as a backup, which is now in use.
Hopefully, the satellites keep working............
