Stray's avatar
Stray
Orbi RBR50 firmware update V2.0.0.74 fail
I have V1.4.0.34 firmware installed on the Router and satelite (was loaded when purchased).  There is a new version of the firmware 2.0.0.04 that is available on line.  The only way to get this insta...
  • loomis1975's avatar
    Oct 01, 2017
    You can't use the RBR firmware file to update the Satellite.  It needs the similar file named RBS.  RBR=Router.  RBS=Satellite.
    Two different upgrade firmware files.
