Jul 04, 2019Guru - Experienced User
Orbi RBR50 is not supporting 900Mb+- on the WAN to LAN test
So I'd like to call NG's attention to the following test results for Orbi RBR50. I'm not seeing anything near 900mbps on the WAN to LAN test. Using both iPerf and Duckwares simple WAN to LAN test pro...
SW_
Jan 03, 2020Prodigy
With the latest firmware v2.5.1.8, Orbi is able to hit ~900Mbps in AP Mode or ~700Mbps in Router Mode.
Wireless backhaul is around 400Mbps-500Mbps:
Kringel
Jan 08, 2020Tutor
Thanks for your information.
I can also confirm that with the new firmware (V2.5.0.108) installed it is working much better. I'm getting a much higher speed (~900Mpbs).
- ISST107Mar 07, 2020Tutor
Good Morning: I am running the RBK53S-100NAS from (Costco) (Firmware V2.5.1.8) on a Macbook Air (Catalina OS) everything is updated. I had ATT Fiber 300 Msps and I could easily get ~ 350 down and ~350 up using the Orbi on Wifi. I ugraded to ATT Fiber 1000 and using the Orbi in the Router mode, I can only get ~ 380 down and ~ 400 max up. I called Netgear supprt (2.5 hrs on the phone) and they said I should be getting ~ 500 Mbps down and up via Wifi. Hardwired I am close to 850 -900 Mbps. Should I return this router and try another brand?
I changed the 5GHz channel (i think from 44 to 42) and now my wifi speeds are 362 and 460 so that's a bit better. Still not close to 500+ as I was told. Thanks
