aravind_eee203
Apr 01, 2021Guide
Orbi RBR50 is pink, but satellite doesn't show any light
Hi, My Orbi RBR50 router has pink light, but satellite doesn't show any light and internet is working fine. How can i get rid of the pink light on router and what it means to have the pink light?...
Apr 01, 2021Guru - Experienced User
Check the user manual for the C series modem on operation modes. There maybe a Router or Bridge or NAT mode some place that needs to be disabled.
aravind_eee203 wrote:If i launch the Orbi app on my phone it tries to detect product and says Router not supported, but it was working fine before this pink light. Also if i try to connect to www.orbilogin.com or www.orbilogin.net its auto directing to netgear.com. I tried using IP address 192.168.1.1 as well. Not sure if there is another way
aravind_eee203
Apr 01, 2021Guide
Sure. But how can that change overnight when none of the connections are touched. It was conected the way its now and working all these days.
- FURRYe38Apr 01, 2021Guru - Experienced User
Anything can happen at the modem which can cause odd things to be seen at the RBR.
If you can get to the RBRs web page and log in, you can see if the modem is bridged or not by looking at the Advanced Tab/Internet secion box. If you see 192.168 something listed here, then the modem isn't bridged. If you see ##.##.###.### address listed, then the modem is bridged.
- vajimApr 01, 2021Master
and more importantly (it's a secret) check your firmware
- aravind_eee203Apr 01, 2021Guide
I rebooted the Orbi, now the pink light is gone. Thanks for your support!
aravind_eee203 wrote:I rebooted the Orbi, now the pink light is gone. Thanks for your support
nice....when you have a chance....check your firmware
