VistaGrande
May 18, 2020Tutor
Orbi RBR50 Non responsive, won't factory reset
After two years of working flawlessly my Orbi RBR50 router stopped working. I have two satellites RBS mdels connected to it. The power light is on and it is green. I tried to cycle the power - did...
RonRolfsen
Oct 15, 2021Guide
Thanks for the reply
This reset method was also posted in previous posts - I have tried holding the reset while powering on multiple times - more than a minute in one trial without any power LED light flashing. Appreciate the help.
wwlen1
Oct 15, 2021Guide
Sorry it doesn't work.
Hope you get it figured out.
