Dave_G20
Oct 07, 2018Aspirant
Orbi RBR50 not resetting password and UID on paperclip reset
I have tried everything with the paperclip on my RBR50. Until it turns orange and blink, until it turns orange, until it goes back to green. Turning it's pwoer on and off, unplugging devices, and it...
Oct 07, 2018Guru - Experienced User
When using the reset pin hole and holding it until the top turns on AMBER and let go. Did you clear browser caches and exit and reopen the broswer while the router reset? Try a diffrent browser?
Dave_G20
I cleared the cache and reopened the bbrowse but that didn't help. I finally did get it. apparently it didn't change or accept the capitalization on the user ID (I had it set to ADmin - wrote it down and it apparently wanted admin along with the old password) the funny part is it asked different security questions than when I set it up, so I couldn't give the answers to it. At any rate it will work well enough like this. Thanks for the quick responses...
- FURRYe38Oct 07, 2018Guru - Experienced User
Ok,m glad you figured it out. Ya, the reset pin button should work to clear the settings including the PW. I would use the UI and do and ERASE and go in and reset up the system again and this time give new information, write this information down for safe keeping later on.
Enjoy. :smileywink:
