BeyondSeek
Jun 29, 2018Aspirant
Orbi RBR50 wire connection why so slow...
Hi,
I have plan 300Mbps. Before I direct wire connect from my modem , speedtest.net get 300 DL/UpL speed. But when I connect my pc via Orbi RBR50, speedtest just get 100Mbps speed. Just the wifi sp...
BeyondSeek
Jul 04, 2018Aspirant
The factory reset is it mean the : Revert to factory default setting?
Ulairi
Jul 05, 2018Luminary
Yes -hold the reset button down until the light flashes amber. Do stats first, then the router
