cosmo115
Mar 21, 2019Tutor
Orbi RBS50 firmware updates went well, but RBR50 can't be updated
I have two Orbi satellites and a router. I manually updated the satellites (Version 2.3.0.32) first as instructed and all went smoothly. Now when I try to manually update the router, the router doe...
- Mar 21, 2019
I believe what you are doing is correct, but you cannot update the RBR50 directly to the objective (.32) firmware.
This has happened because Orbi's checked the firmware image when you upload it to make sure it is not too big... they hard coded an artificial size back in the day and now they had to exceed that size for firmware .32.
The only way to mitigate that problem is to have an intermediate firmware version that resets (makes larger) the .img file checker and allows much larger firmware images to be uploaded.
Search in this community for the intermediate firmware (there are threads all over about it) and manually update your router to the intermediate version, and then update it to the objective (final) version.
I know this is a pain, but the final version is far more stable and reliable. It will be worth it.
Chuck_M
Mar 21, 2019Mentor
