AllOuttaBbleGum
Jul 18, 2024Star
Re: Orbi RBS50 stuck on Config Sync
Thanks for this thread. Was having the same problem. I found I only had to connect the RBS50 to the RBR50 with an ethernet cable temporarily. After about 5 minutes the Backhaul Status changed from ConfigSync to Good. Then I unplugged it and moved it back to its original location and the status has stayed Good. It's a three satellite wireless mesh arrangement in Access Point Mode with a Firewalla Gold as the router. The router is centrally located in the middle of the property inside the main house. The satellites are located halfway to the property lines. I get great coverage over the entire house, outside structures, and property (10,500 sq ft). It is generally reliable.
No RepliesBe the first to reply
