Bill____
Apr 06, 2018Apprentice
Orbi RBS/RBR 50 Version 2.1.3.4 and Apple homekit iDevices and Philips Hue problems.
I have updated to firmware version 2.1.3.4 and have noticed some homekit instability. I have several iDevices Switches which have become intermittent and no other changes than the router firmware. ...
bent_wookie
Apr 27, 2018Star
eljarviso wrote:
The NVRAM setting resets after a reboot of the device. I ended up putting my asus router back in and running the orbi in AP mode. I then put in firewall rules to block the download servers netgear uses to push out updates.
I feel like mine must have rebooted since I installed the beta, but I like the idea of really walling it off from Netgear. What servers are you blocking?
eljarviso
Apr 28, 2018Luminary
Looks like the IPs I blocked were AWS so they change. I ended up blocking all traffic coming from the orbi AP IP.
- caseywebdevApr 28, 2018Initiate
I'm glad I found this thread. I was about to reset my HomeKit configuration which would have been a giant PITA. I have 40 or so configured accessories and since 2.1.3.4 they bounce between all available and all "Not Responding". As soon as I downgraded the router and satellite to 2.1.2.18 everything is working perfectly again. Hopefully we can make enough noise to get Netgear involved. If they won't revert the mDNS flood protection change we at least need an option to disable that so HomeKit can operate.
