steeve725
Mar 12, 2019Guide
Orbi remote management shows wrong model
Hi, Everyone Had my orbi system for a few days and really like it. Just dealing with what I think is another bug. Yesterday when I was away from home my remote management wasn't working. Wh...
ekhalil
Mar 13, 2019Master
steeve725 wrote:
Firmware versions;
App - 2.2.13.22
Router - 2.2.1.210
Each satellite - 2.2.1.2.04
I noticed when I click on settings in the app, then "about" it also shows RBR50
Thanks
steeve725 There is a new Orbi iOS app released today 2.3.0.31. Please try it. I still think this is juat an issue in the NG database where missing models need to be added, but please give this a try. :)
steeve725
Mar 13, 2019Guide
New orbi app didn't make a difference. My router still shows as an rbr50 instead of rbr40 when off wifi and using remote management.
- FURRYe38Mar 13, 2019Guru - Experienced User
I would try the FW update...
steeve725 wrote:
New orbi app didn't make a difference. My router still shows as an rbr50 instead of rbr40 when off wifi and using remote management.- steeve725Mar 13, 2019GuideOK. So I guess that's another bug.
Because you obviously can't believe what the gui tells you when you check for updates. I checked for updates and it tells me my firmware is up to date @ 2.2.1.210
That's frustrating for the average person who believes what the router tells them when they check for updates and nothings found, because there still might be an update out there.
